Posted: Thu Nov 17, 2011 6:50 pm Post subject: ENGINE PARTS |
Pay attention : most of engine parts are out of stock/no stock at AM :
pistons, crankshaft, cylinder tubes...
Now you know ! _________________ Welcome to Paradise ! (FRONT 242)
Rodolphe
Posted: Thu Nov 17, 2011 11:43 pm Post subject: |
Bonjour Vincent,
C'est juste momentané pour toi ou en attente de refabrication des pièces comme chez Mercedes ? |
Scott
Joined: 30 Jul 2010 Posts: 14 Location: Michigan & Carolinas - U.S.A.
Posted: Wed Jun 25, 2014 5:35 pm Post subject: |
Hello,
I see this is an older post. Is there any update as to availability of said engine internals (Pistons, RINGS, Cylinder Tubes, Cams, Crank)? I know of a few sources that can fabricate pistons and rings stateside. Hopefully, Aston Martin hasn't abandoned us like the folks at ALFA Romeo. Disco is in again apparently, as in "DISCO"ntinued.
Thanks,
Scott _________________ Evel Knievel had the right idea. 13346, 6,805mi |
Posted: Wed Jun 25, 2014 5:44 pm Post subject: |
| Scott wrote: | Hello,
Thanks,
Scott |
I have to check as I was ( and I'm always ) busy to rebuild an engine.
If there is no issue, Icould send my engine to RS Williams to get a 7.0 litre conversion, and put it in 13295  _________________ Welcome to Paradise ! (FRONT 242)
Posted: Thu Jun 26, 2014 8:51 am Post subject: |
There are a number of companies in the UK rebuilding these engines - RSW, Oselli Engineering, Rikki Cann etc. so the parts must be available, at least from them. The different engine builders have different upgrades on capacity, some requiring a new crank, some not. The added challenge with the Lagonda is the short inlet manifold on the carb cars.
There have been several discussions on the AMOC forum about engine upgrades, which usually start at the point where someone requires a rebuild - the added cost of a capacity increase is not necessarily that significant when you are rebuilding anyway. One important point is that some upgrades are more suitable for manual cars as the added power/torque is at the higher rev ranges.
Scott
Posted: Mon Jun 30, 2014 8:09 pm Post subject: |
Vincent,
I sent you a PM.
Thanks,
