Posted: Mon Oct 04, 2010 12:51 pm Post subject: Tyre Specifications |
Hi Folks
I am looking to put new tyres onto my car and there seems to be a considerable choice available in many price ranges but the speed ratings all seem to be quite low. It is my usual policy to put a high specification quality tyre on my cars as these are the only things that are actually in contact with the road.
What is the best tyre that you use on your Lagonda's with regards to make, speed ratings, load ratings, run flat grade etc.
Keith |
Posted: Mon Oct 04, 2010 3:41 pm Post subject: |
235/70 VR15 ( max 150MPH/240KMH)
GOOD YEAR EAGLE M+S RS.A LOAD 102 ON 13034
AVON TURBOSTEEL Whitewall LOAD 101 ON 13295
The tyres are new on both cars, comfortable and not noisy, with a good driving feeling. _________________ Welcome to Paradise ! (FRONT 242)
Posted: Tue Oct 05, 2010 5:35 pm Post subject: |
I use the Avon on my car since 2005.
They look fine to me! |
Posted: Wed Oct 06, 2010 7:24 pm Post subject: |
Stick to the original specs tyres
Avon Turbosteel CR11B
You get a good deal from camskill.co.uk whether with whitewall or without |
Posted: Thu Oct 07, 2010 8:12 am Post subject: |
Thanks Guys. I appreciate your help.
I am going to go for the Avons as they seem to have the best specifications. |
Posted: Fri Oct 08, 2010 12:03 pm Post subject: |
| Avon Turbosteel on mine. |
Posted: Thu Jan 19, 2012 8:42 am Post subject: new shoes for your the winter |
| Avon Turbosteel CR11B are currently at a low £ 120 ea at camskill.co.uk + £6 p&p for 2 tyres to UK and only £8 p&p for 2 tyres to Europe. |
Posted: Mon Feb 27, 2012 11:40 am Post subject: |
Yes I bought them and they were at GBP 604,00 for 4 tyres including p & p but plus VAT (!).
Good choice!
/M |
Posted: Mon Feb 27, 2012 2:26 pm Post subject: |
Relating to tyres, can anyone tell me if filling a tyre with pure Nitrogen gives any real benefits to a car?
I was told that Nitrogen does not fluctuate with temperature and that the molecules are larger than normal air molecules so air loss is much slower "through" the tyre itself. This, therefore, means the tyre remains a lot more stable and hence gives better tyre wear, but would it really make that much difference? I am sure we all check our tyre pressures regularly so I am skeptical to claims of prolonged tyre life.
Also, is not "normal air" made up of about 75% Nitrogen anyway? ? |
Posted: Mon Feb 27, 2012 6:18 pm Post subject: |
Keith You answered your own question.
Lets say 25 % of original volume would "leak away, after that you refill 25 % of tire volume of a 75 % nitrogen.
Personally I say Salesman gossip !
And if a tire does not seal to rim bead those mighty big molecules won't help either.
Posted: Mon Feb 27, 2012 6:44 pm Post subject: |
The benefit to the average motorist is that they don't go down as fast.
The benefit to a classic car owner is that the tyre doesn't contain any oxygen under pressure which will speed up the ageing process of the tyre and so it should last longer before you need to replace it due to the rubber hardening and cracking.
As to whether this is an actual or thoeretical benefit though.. If you fill a tyre with air and the pressure drops over time then there is a higher percentage of larger molecules left. Then keep topping it up and repeating this - you end up with a nitrogen-filled tyre! |
Posted: Mon Feb 27, 2012 7:19 pm Post subject: |
If I fill my tyres with Helium will I go faster, fly or explode?
Posted: Mon Feb 27, 2012 8:19 pm Post subject: |
| Helium is inert. Hydrogen maybe.. |
Posted: Mon Feb 27, 2012 8:57 pm Post subject: |
Thanks Guys.
I think the benefit, (if any), for the average motorist is negligible.
More info here - which seems pretty sound advice.
http://www.tyresave.co.uk/nitrogen.html |
