mikke
Posted: Tue Jun 21, 2011 8:49 am Post subject: Hello ,lagonda with problems. |
Hello my name is michael from spain ,i am restored a lagonda number 13223 ,i dont have nothing information about this car ,i need some information about the valve timming ,because i bought the car with the engine dismantle,i dont know what there are the corrects marks for camshaft .
can someone help?
Sorry for my english.
thank you.
Posted: Tue Jun 21, 2011 2:27 pm Post subject: |
Michael
I will look in the file & email you. |
mikke
Posted: Tue Jun 21, 2011 6:07 pm Post subject: |
thank you .
the engine is running, but it has explosion to carburetors (1500rev aprox).
the engine was in a box ,but i could re-assemble,i think it is out of time .
i dont have information about this engine
thank you again.
and..again sorry for my english.
regards
michael. |
Posted: Wed Jun 22, 2011 10:16 am Post subject: |
Mikke,
If I understand spanish is your mothertale, do you speak a little bit of french ? It could be easier for me to understand what's the problem with the motor ( in a box, dismantled ? ).
We've already 'remade' two motors and may help in case of need.
Welcome to the 'Mad Guys World' ! _________________ Welcome to Paradise ! (FRONT 242)
mikke
Posted: Wed Jun 22, 2011 5:50 pm Post subject: |
sorry i dont speak french,and a littel english
yes the engine ,...(well ,only the cylinder heads ,)was disassembled.
i need know ,how can i to do the valve timing?
(google transducer)
salut pas beaucoup français, si, le moteur a été démonté, bien, seulement les culasses, j'ai besoin de savoir comme il est fait, le réglage des chaînes du temps.
saluts |
Posted: Wed Jun 22, 2011 6:30 pm Post subject: |
Ok, now I understand.
Pay attention, if the cylinder head gaskets were 'out'; that's mainly because of the poor cooling system of the Lagonda. Check the waterpump ( if it rattles on the axle, it has to be repaired or replaced ) and certainly clean the radiator ( or rebuild it; it's cheaper than to buy a new one from AML ).
To make a good job, the motor needs to be put out of the car, otherwise you will not success to screw the cylinder heads at the right torque; and the work will need to be redone a few months later.
The method is described in the owner's book ( torque, and so...) but I can scan and post if you need or download the manual here :
http://www.astonmartinlagondas.com/downloads.htm
All the gaskets are easily available at AML dealers at affordable prices.
More later. _________________ Welcome to Paradise ! (FRONT 242)
