Posted: Sun Mar 20, 2016 4:49 pm Post subject: belt & sensor |
Does anybody have a Gates code (or length and width) for the belt that runs from the water pump to air pump (located on the right hand side of the engine)? Part number is 05.17002
Secondly, the sensor in the radiator for low coolant level is leaking. When I had the radiator out I was already a bit concerned that the copper pin in the center pushed in and out very easy. I guess there is a sealing O ring inside which dried out. Does anybody have experience with getting these things leak free? When the cooling system gets pressurised, the pin moves out a bit and there is a small leak. |
Posted: Mon Mar 21, 2016 8:27 am Post subject: Re: belt & sensor |
| JohanB wrote: | Does anybody have a Gates code (or length and width) for the belt that runs from the water pump to air pump (located on the right hand side of the engine)? Part number is 05.17002
It all depends on how you want to get your car back to life and on which standards, but the air pumps are really not necessary. Mines are in a box since I bought the car...
About the radiator could you send a picture, because I think I have the part available for repairing. _________________ Welcome to Paradise ! (FRONT 242)
