Posted: Tue Feb 12, 2008 5:45 pm Post subject: charge of airconditioning |
I think the aircon' gas in the factory was R12. Now unavailable, is the system also operating - without attempting failures -with R134, with the change of some leadings ?
Any experience ? Thanks for your comments... _________________ Welcome to Paradise ! (FRONT 242)
Posted: Wed Feb 13, 2008 5:50 am Post subject: |
Hey Vincent, no problem with the new stuff, you just need two replacement connectors for the high and low pressure lines and a new "dryer".
For the oil you can get special retrofit spec too, the name/type I can't
recall at this moment,( tonight I will if you want )
If you still don't trust it you can ask for 412 (specially for retro-s) but personally I think it comes unhandy when one has to refill later.
Posted: Fri Aug 22, 2008 9:04 am Post subject: |
Yesterday mine was refilled with R12. So, it is available here in Switzerland
Zoran |
Posted: Fri Aug 22, 2008 3:47 pm Post subject: |
Cool ,it's illigal for at least 7 years
Posted: Sat Aug 23, 2008 11:11 am Post subject: |
| Zagato wrote: | Cool ,it's illigal for at least 7 years
Maybe Switzerland is not submitted to European laws ! _________________ Welcome to Paradise ! (FRONT 242)
Joined: 02 Dec 2007 Posts: 38 Location: New York, USA
Posted: Thu Aug 28, 2008 8:20 pm Post subject: |
| I have been using freeze 12 for years since there is some risk of seal damage without doing a full flush and converting to R134. It works just fine. |
Posted: Wed Jun 03, 2009 10:04 am Post subject: |
Nice day today !
The air conditioning of my car works !
But just to optimize the system, can someone tell me the exact quantity of R134 to put in ?
With 700 grams, the compressor switches always on/off.
Any idea ?
Thanks _________________ Welcome to Paradise ! (FRONT 242)
Posted: Mon Jul 13, 2009 6:02 pm Post subject: |
Nobody here who can help me ?????????????????????????????
700 grams ( 22 oz ) : too much, enough, too few ? _________________ Welcome to Paradise ! (FRONT 242)
Posted: Tue Jul 14, 2009 2:42 pm Post subject: |
Sorry, Vincent
I do not have the competence needed to help you with this one...
Posted: Tue Jul 14, 2009 3:22 pm Post subject: |
We put about a kilogram in 007, but it has a twin set.
But its a trial and error thing it was not designed to run with the 'new'gas,
so do an 850 and run it again.
Posted: Tue Jul 14, 2009 4:30 pm Post subject: |
Dank U wel Harry,
13295 is also fitted with a rear unit; I'll try if better then. _________________ Welcome to Paradise ! (FRONT 242)
Posted: Fri Jul 17, 2009 1:26 am Post subject: |
Vincent, I think you need more. Assuming it was empty, then you would need at least 32-36 ounces to fill. You can use the cheapo gauges that come with the R134 cans, it will suffice to tell you if you are over pressurized.
Does your car have the a/c compressor full button? This would be a blue button located on the left of the dash where the hazard switch is. If this is on and the compressor is cycling, you are low freon or you have an a/c component problem.
There should be a wire from the compressor to the relay (type "C") on the programmer. If that is constantly hot and the compressor is cycling then it is low on freon. Otherwise, I will start looking for the AC documentation because you are going to have to start trouble shooting the programmer. |
