Posted: Wed Aug 16, 2017 10:20 am Post subject: Chassis number |
| David has discovered, not known to he or I before, that the chassis number is stamped on a plate under the bonnet lamp. |
Posted: Thu Aug 17, 2017 9:27 am Post subject: |
Apparently also on the headlamp surrounds, the headlamp cowls and
the centre spar for the bonnet. |
Posted: Mon Aug 21, 2017 8:39 am Post subject: |
On which cars ?
When the VIN numbers were short ( ex: LOOR13034) the chassis numbers were stamped on the right rear side of the traverse ( link ) under the gearbox. When the VIN became with 17 positions, it has been stamped on the right side of the chassis behind the wheel, on the front.
I think the position dépends on the side of the steering wheel too, or I'm wrong? _________________ Welcome to Paradise ! (FRONT 242)
Posted: Mon Aug 21, 2017 11:26 am Post subject: |
I've seen full 5 digit VIN on the underside of the bonnet (beneath the bonnet lamp) on 13282, 13302 and 13380 so far.
I've seen quite a few headlamp surrounds with the VIN stamped, just as the last three digits.
On the headlamp cowls and the centre spar (only seen this on 13380), again, it is the last three digits only.
Posted: Mon Aug 28, 2017 2:08 pm Post subject: |
This could be the production marking like the numbers we could find on some pieces of trim...
Don't forget there are for example two different types of bonnet ( US cars bonnets have a quite different curve because of the taller airbox.) _________________ Welcome to Paradise ! (FRONT 242)
Posted: Mon Jun 11, 2018 1:55 pm Post subject: |
Now also found on all innerwing-dustshields
And on rear door C-post covers.
Feniks. |
