Ian Whittaker
Joined: 22 Feb 2022 Posts: 9 Location: Northampton, England
Posted: Tue Apr 12, 2022 12:20 pm Post subject: Fuel Pump |
Hi, 13121 will shortly be on route to my garage, so I can start to work on it. The car is/was missing a fuel pump, which I have now obtained for the hole in the fuel tank. Does anyone have any info how it is supposed to be sealed/fitted to the petrol tank??
Thanks Ian |
Posted: Wed Apr 20, 2022 7:47 am Post subject: |
Fuel pump ref is 34.16140. I suppose it's fixed as a 'push-and-turn' with a gasket or seal (no screws). _________________ Welcome to Paradise ! (FRONT 242)
Ian Whittaker
Posted: Sat Apr 23, 2022 5:30 pm Post subject: |
| I now have the car in my garage, and have unloaded the boot of the car, and found inside in a small bag a circular plate, with allen key bolts, which match the hole in the petrol tank, where the pump is fitted! Looks like I have answered my one question, but thought I would post the update, in case someone else gets the same problem!! |
Posted: Mon Apr 25, 2022 8:32 am Post subject: |
| As for fuel pump and sender there is also a rubber gasket needed and yet again standard UK stuff so go to Landrover,or BL supplier as mentioned above. |
